did u use any glue on that box if not u need 2
other then that looks good
wut sub is it for
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
port looks tiny and you built a dog house not a sub enclosure.
mdf is the best to use for wood. :P
wut sub is it for
of corse glued everything its for my lanzar max pro would love to upgrade it but too broke for now
For beats Click Here
Head Unit- power acoustik 8" touchscreen
doors-RE 57 fr
sub - sundown audio e8
amp-PG v752
port only had to be 1.5"s wide i know mdf is the best but i had that wood lying around and figured why not build a box for my sub... hey its better than my prefab
doors-RE 57 fr
amp-PG v752
Seems pretty small even for a single 10.. Also what kind of wood is that?? and where are u gonna be running the speaker wire?? Doesn't look as if u drilled any holes for a terminal cup or even for a small hole just to run the wires through. Also for another 2-3 dollars or so you could have bought sum sealant to make sure that it would be all air tight.
Pioneer AVIC-N2
gonna be drilling the holes on the right side today for the terminal peice, the wood is just ply wood i know its not the best wood to use but i used what i had
doors-RE 57 fr
amp-PG v752
X2 on Marlo. go get yourself a small tube/bottle of liquid nails and put it on the edges.
Other than that I think it's about right for a small 10".
Liquid nails isn't exactly the best sealant to use... The best IMO(besides resin + glassing) is standard white bathroom/kitchen caulking. This is the kind I use for cheap boxes for locals on a budget, DAP Kwik Seal(I get it at Home Depot for a couple dollars per 10oz tube).
Pioneer AVIC-N2
thats not bad gonna have to go pick me up some
doors-RE 57 fr
amp-PG v752
