First of all you won't be seeing anywhere near 6100 watts so u can get that fantasy out of your head.. Second DO NOT mix and match woofers.. Third, my suggest would be to sell the Lanzar amp, RF woofer, RF amp, and Pioneer amp... Then use that money to buy a better quality amp for the L5s, build a proper enclosure and install everything the correct way(proper wiring, amp settings, HU settings, etc).. Next i'd suggest that you read as much on this forum, bcae1.com, and other forums to get sum more product and install knowledge.
Pioneer AVIC-N2
