06 Honda Civic rebuild
Ya, hurry and get this done lol ^.^ I want to see this build ASAP :).
1999 VW Passat GLX:
AudioPipe 1500W
10' Alpine Type S(2)
Pioneer DEH-1300MP
1/0 RF Amp Wiring
Big 3 - 1/0 RF Wiring
Stock Battery and Alt
Okay so first things first. I decided to redo my box first with two 4 inch aeroports firing into my reardeck :hairtrick:
I took off my back panel, didnt take long just had to remove two screws and pull it off. I didnt want to have to do any cutting into my rear deck, so I opted to go with 4 inch ports vs 6 inch, however after doing a dry run with a small 4 inch pvc it seems Im going to have to cut about 3/4 inch off or bend a small metal piece anyway. :sorry: You can kind of see it in the picture. Ill get a better one soon. Just a small update. Im hoping to start 'working' on my box after thanksgiving.
rear 6 1/2 speaker thats coming out. for the blow through :spiteful:
rear deck after right 6 1/2 is removed
Test piece of 1 4 inch PVC pipe
The problem. Gotta cut or bend this little piece here
Edit:
I woke up this morning to work on cutting the 'problem piece' out and bent my blade. Then I realized I would not be able to fit 4 inch ports in there regardless because of my trunk rails. Instead Im going to do 2 3 inch x 8' ports. Hope I dont get any port noise. Update tomorrow.
Current build:
Pioneer AVH-P3100DVD
Soundstream EQ
RF Components (5 1/4, 6 1/2, 6x9 x 2)
Two Fi-BTL 15's
One RF T1500-1bd Amplifier
T400-4bd
XS Power 608
XS Power D1200
Optima Yellow top 34
Soon to come:
Another RF T1500-1bd
HO Alt
1-6 more XS power 680
Team D.M.V
  • 4 weeks later...
Sorry it took so long for the update Ive been PRETTY busy. Anyway I decide to work on my door panels first instead of the sub box. Heres some pics.
Panels just covered in fleece
This is with a coat of resin applied
After bondo has been applied and first coat of primer
I sanded again after this but I did not take any pics :-( sorry. I found out from a paint sho[ that this is supposed to be one of the best paints to reduce chipping and that actually BINDS itself onto surfaces so that it bends with the material it is applied to worked pretty good for me and it is HIGH SHINE.
In between wet sanding with 320 grit paper
Final product
It could be better. I feel like black brings out a lot of the imperfections ESPECIALLY around the edges. :censored: ANyway....The wet sanding REALLY helped with the glossyness. I can almost see my reflection. I still have 3 more panels to work on. Wish me luck
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
No love?. :search: ... Anyway I started working on my front panels.
The beginning
After I had applied roughly three layers of fiberglass, bondo'ed applied primer and three top coats this was the outcome.PICT0409.jpg
It looked OK but it was still rough around the edges. I decided to cover it with carpet and use Krylons fusion for plastic paint on the parts of my door that were not fiberglassed ( picture of the spray paint on next update) This was the outcome :lol:
PICT0410.jpg.
So now I have to work on the other 2 panels. Also Ive got a surprise on the way :spiteful:
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
not to bad man, just keep working and it will start to come together
TEAM NEMESIS
my system
1) us amps MD3D, us amps md21
2) kicker solo x 12 in 2.7ft^3 at 37hz
Meca scores
1 xxx12" 141.8db at 40hz,
1 18 rd alpha v.2 145 db at 38hz , 2 12 orion hp 144.9 at 43hz
Refs: hollatchaboy, schrummy, nitro_freak1,Brandon15zzz,Hellbound Train
I always like to see honda builds
...i can't figure out why lol
I know if I ever find out you were messing with my 17yr old daughter, i'm diggin' off in that ass and then your next post will be asking for tips on how to remove my size 12 shoes from your ass.
Open Up The Trunk
Pioneer P6000Ub H.U.
Sundown Saz-1500D
Hifonics ZXi 4410
12" Directed SX12D4 (x2)
12" 1500rms Sub x1
Front - Powerbass 4XL-65-92 Mids
Rear - Cadence 6.5" Mids
Electrical Under Construction
Check Me Out(CarAudio Vids)
Official Feedback Thread
Check Out My Music Page
Thanx! I should have an update by tomorrow night with possibly 3 door panels done. :spiteful: . Hopefully Ill be able to start on my box build after that
lol
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
Update: So I decided to cover all panels with fabric. ALOT easier lol. I have three installed and in my car now finishing up my 4th and final panel tomorrow. For you picture lovers, sorry no pics yet. I have some but they were taken at night and they dont look that good so I'll take more in the morning. AND I received my surprise today :D . Pics tomorrow.
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
