static noise when engine reved up
anyone know how to eliminate engine rev type noise through your speakers, i think it might be the alternator
there are so many possibilities, therer was a tutorial that wayne harris did a while ago it is on termprohere it ishope this helps in any way
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
thanks man im going to try some of those tommorow i think my problem is im using the factory ground for the head unit
what type of headunit do you have?
let me guess, pioneer?
simple fix then.
wrap some bare wire around the rca's where they plug into the headunit and then ground those to your factory ground.
i usually strip about an inch off of some 18 gauge speaker wire (or similar) and then wrap it around the rca connection really good and then tape it up with some electrical tape.
its a very common problem with pioneer headunits
or if you don't mind spending money then get one of these.
http://www.darvex.com/SGN20/Stinger+Ground...p+Isolator.html
both will fix your problem
