so here goes someone please correct me if im wrong or im just a fuckin idiot
i installed a new windows xp onto my desktop its a dell optiplex gx620 i just recently in the last 3 days tried to download all the drivers that the dell website said should be installed using my service tag heres the problem my roomie installed a few other drivers that didnt belong so for instance when i try to play a game like halo for pc it will either say runDXDIAG ???????? is that direct x and how the hell do i get it lol if it does go through to the menu screen on the game it just freezes up and i have to turn my comp off manually also if this helps when the game is opening my toolbar on the bottom of the screen looks all weird and pix elated
must be nice huh
reinstall Direct X with the latest version.
if you go into Run then type dxdiag in the box that pops up then itll take you to what its talking about. it just has info on all the drivers etc
ok will try and reinstall direct x now and try the game will be back here shortly
must be nice huh
yeah so its a no go sorry not workin i tried to run the diag and it says there are no problems yet i tried the game and once agian it froze and now all the images on the comp are pixalated
must be nice huh
you think it was working fine before the new install and now like when i go to watch a video and such the colors are all bright and wrong almost as if im watching through a thermal imaging camera except more defined so my best bet would be to go and get a new vid card huh
must be nice huh
best bet i would say is definatly do the direct x update and dont forget to update the graphics card drivers. you most likley on default windows drivers .
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
did u update the video card drivers
1996 Chevy Tahoe
AKA My SQ Hoe
Pioneer AVH-X2800BS
Precision Power PC.18DS
MB Quart NA540.6
Skar Audio RP-2000.1D
55-3210 -  8 Inch MCM AUDIO SELECT
Rockville RXM64
Tymphany BC25SC06-04
Kenwood KFC-1795PS
i did indeed i updated bothe direct x and the vid card driver at least from the dells web site and what it said i needed for the vid card i have version 9.0 for the direct x or whatever so ........ i wish i had someone here to see wtf is going on to alot of you its probablt something simple but like i said im a noob to computers are somethings are just better left alone lol
must be nice huh
check your display properties on the control panel and see what your color setting is set to and also your resolution sounds like your in 256k color mode
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
