It still has bass but if i barely turn it up its making a weird noise like the wire is loose or somthing. like a pop or something. it also does it when i first turn on my radio, all my speaker wires going from sub to amp are tight as can be.
Any help?
Thanks..
1.5cbf box with turned around 37hz or 30 something i frogot.
Edited by Chrisn077
18" DC Level 4
what kind of RCAs are you running, it sounds like a signal issue
1997 Pontiac Bonneville Black on Black on Black
15" DC Sound Labs Level 5 w/ quad coil in a T-Line tuned to 35 hz
7" Jensen VM9311TS Touch Screen Flip Out w/ J-Link
Blue Custom Trim
Blue Custom Fiberglass Rear Speaker Pods
Autotek Mean Machine MM2000.1
1/0 Knukonceptz KLMX
Rockford Fosgate Twisted RCA's
2 Audiopipe Anl fuse holders w/ 200A Kicker fuses
2nd battery (Soon to be an Odyssey D3100)
Dynamat Extreme Bulk Pack
Custom False Floor
15% Tint All Around
Custom Painted Stock Rims
My Build Log
Tailights
15" Lvl 5 DC T-Line Build
I dont know but my head unit only has one "sub out" so i had to use a Y adapter for both the RCAS.
The RCAS came with a amp kit. i think boss
Is that what might be causing it?
Edited by Chrisn077
18" DC Level 4
What type of amp? Two channel?
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
It sound like a signal issue. Take out the DC and check the coils just to be sure. But its sounds like your RCA are getting a bad signal. But first try grounding your rca's at the deck or someplace if you can. If its a pioneer deck (which are notorious for having loose RCA grounds), then Im sure its your issue. IF that does not work try switching out the RCAs with another.
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
I just took it out and the tensel lead or whatever its called came off the plug in for the positive on one side. it looks like it can be crimped backon?
not surprised that the lead snapped.... depending on where it snapped you should be able to solder it back together. If not just email Rusty and he will take care of you.
  • Who's Online   0 Members, 0 Anonymous, 2567 Guests (See full list)
