Money isnt easy to make. I know it may be cheaper and most guys here dont believe in low end but at least you would have some beat. I personally have seen a few of those trucks but never with any type of system so definitely post up pics of the install. I know there may be some out there with installs but I myself have yet to see one personally.
This is true, but if the money from those two subs and amp are 1/3 of the way to the other gear, wouldn't it be shrewd to just keep saving and get what you want?
Just guesstimating since last time I got an estimate for 1508's they were $150 apiece, then a decent amp to push them, maybe $2-400?
Too many projects, too little time...
haha yes women break your wallet especially when it comes to money for your install. might be good to save up for that install and while saving do some deadening a bit at a time. This would ensure the best sound when you do finish and you will be highly proud when you get the install completed.
yea i mean if you think about it in the long run you will have aucually saved money because you would have to buy the 1st then sell it for mabyee 3/4 of what you got it for if youre lucky. and damn women why are they soo good at making me spend money
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
ied try this set up, about the same price n should be better equipment also
amp = http://www.woofersetc.com/p6401/KAC8104D--...t-Amplifier.htm
sub = http://www.woofersetc.com/p2848/DS12D4--Di...l-Subwoofer.htm
ive heard that kenwood amp is good, n diamond subs are pritty good also
that system will be prolly less cost wise n should sound alot better too
ive personally heard 2 of these http://www.woofersetc.com/p6394/TSSW301--P...t-Subwoofer.htm on a mtx 1501d n they hit lows pritty good n got pritty loud also in a small box
if i was u ied make the box liek a downfire but face it twards the back of the cab n give the sub around 2'' of recess legs n u can angle the back of the box to conture with the seat n mount the amp on other side n should be good to go
if u have it faceing seat u'll have issues with cone surround rubbing n what knot but the rear faceing downfire type box could n should yeald better output, ive heard a setup with that pioneer 12 like this n it sounded pritty good n u'll have no worries with seat hittin sub
heres a vid of that pioneer in action to give u an idea
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
I would try the like $40 hifionics subs at sonicelectronix.com, if you have the room to fit them plus there rated 600W 300RMS i was thinking about getting some
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Hello, im Kevin lately i have been thinking of adding a system to my 1990 4wd Isuzu PUP std. cab. I have been wondering about shallow mount subs and how good they hit im thinking of these Kenwoods http://www.crutchfield.com/p_113KFCWS12/Ke...S12.html?tp=111 on a VERY! tight budget
this is the amp http://www.crutchfield.com/p_158ZZR3301/So...301.html?tp=115 me and a friend of mine are going to be building the box
Thanx
I played around with the shallows for a good year. I ran the pioneer shallow subs back in 2008 that could take 350rms. the ones that had the silver middle cone and black cone. I ran 4 in my single cab truck and they did hit very well for shallow subs. I never got the chance to port them, but in sealed box they did a 143db on the audio shop, "this was done on a AC meter so the reading is not 100% but can give you somewhat of an idea atleast"
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
