need to upgrade electrical system but??
so i am goin to be running roughly 5,000watts
and h.i.d low,high,fog lights which will be on most of the time
whut exactly should i get to upgrade my electrical system
2 jl audio 12w3's sealed
soon to be 4 level 3 15's
blow through
all dc audio
Start with the Big 3. I'm only pushing 600 watts and I'm going to need to do it. Start there.
I guess an alternator too, but I don't really know if you need it or not?
RE SE 12" subs (2) in prefab dual ported box (custom box coming soon)
Hifonics bxi610 mono 600 watt amp
Stock HU
Mach RCU
Apline 5 x 7 S Type Speakers (2) (1 blown)
Stock rear speakers (2)
Pyramid Tweeters (2)
with 5000rms ied look at gettin a good ho alt of around 200amps or so n a good starter battery n a good rear battery n 1/0 run
u can run more rear batteries but that should get u threw with true 5000rms, maby 1 good starter battery n 2 good deep cycle batteries in back n u should be good to go
n maby 2 runs of 1/0 to the back couldn't hurt
http://www.stevemeadedesigns.com/board/ind...?showtopic=1005
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
This is one of the those if you need to ask questions...
But since you did ask, what amp(s) will you be running?? Some amps are more or less efficient than each other and that may play a role in what electrical setup you're gonna need.
Pioneer AVIC-N2
4 dc 1000.1's
im not sure witch amps for the mids and highs yet
blow through
all dc audio
4 dc 1000.1's
For something like that I'd suggest at least this - 300amp HO alt, 4-5 batts(under hood batt - Kinetik 1400/Northstar NSB-70)(3-4 big batts in back - Kinetik 2400 / Northstar NSB-125 / XS 3100 / or similar), Big 3 upgrade in 1/0ga or larger, 1/0 or larger power/ground wires, and a maxxlink to wire all the amps together.
Hopefully that helps.. Btw it's spelled which in the context you used it.
Curious as to why you're choosing to run 4 1kw amps instead of a single 4kw amp... 99.9% of the time the single amp will be cheaper, more efficient, same output, and use less wiring.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 1070 Guests (See full list)
