NO i know it takes alot of money im just wanting to get somthing that i wont get sick of..I am expecting to put in a 250A alt., 0 gauge power,0gauge ground, big three under the hood. Im really good at making boxes. So i will be making my own. and the reason people get like 8k in a system is because they buy like 4 15s and 4 18s...I would like to maximize my 1 or 2 subs that i purchase. I'm prolly guna drop about 3k on this system.. at the end.. Like i said i am trying to plan for this summer. Would 4 jl w3 v2 12" hit a good 145-150? Keep the ideas comming! Thanks for all the help guys
Where did he say that? all i saw was 460 seemed a bit much on 1 sub, and i dont see him doing 150+ if hes not droppin more than that on the subs, at least not in a daily set up.
Look at the part in bold.
Pioneer AVIC-N2
just keep in mind, 3k may get blown real quick...and thor does 150 with <4kw clamped, its that huge stetsom that lets him do the 151.6.
and OP, just remember a good alt is usually in the 500$ price range, a battery is about 400, and wiring will likely run another 500 after all the fuses/solder/wire/rca's/distroblocks/terminals/etc. that means you're halfway through your budget before you actually buy any audio equipment, and if you decide to run 2 or more batts, you can blow 2/3 of tthe budget easily.
Team DC
I plan on putting it in my new car this spring. Idk for sure what kind it will be. I would like a newer impala on some 20"s. And i do plan on spending some money. I am going to build This for comp. So I am not going cheap. I found AQ subs the other day...does anyone have these on here? And Y are w3s a bad set up?
w3's are basically an ok sq sub, a kicker cvr will basically kick their ass any day in the lanes. and AQ is a nasty brand. I saw 2 hdc3 10's break 150 with <5kw. aq would definately be a good way to go, and their amps are damn good as well. 2 of their subs and 2 aq2200's and you should be able to break 150, a few other people have with that equipment already
Team DC
Are there 18's a good sub? because i have not found anyone with an 18 from them. only like 4 15's and 10s. And i whent on there website and they dont list specs for the subs...where can i find the specs?
