Rydaz1Bass Posted December 5, 2009 Report Posted December 5, 2009 Ok i am thinking about making a box for my Rockford Fosgate 12" Hx2 sub.I was going to make the box measurements out by Length=20 depth 30" Height 15" so i went online to the online box demensions calculater and i put in the measurements it came out to be a 4 cubic feet all together.Thats the exact demensions the Hx2 needs.Now my qeustion is what kind of port should i do for this box so i can tune it to the right hurts.A circular port,|===|<---or the port that looks like that.Or should i do the removable like steve meades port on his tahoe box so i can swicth out different sizes.I posted this because i needed some feed back and help so i do not screw up this build and i know you guys are bluntly honest so can you help me out??This will be my first build ever.Does any one have any good information??? . VehicleCurrentlyOwned:2000Malibu \/MySystem\/ Ken-Wood HeadUnit Cars interior panels Custom blue Done by ME Pheonix Power block running both amps Stinger pro series four gauge wire flex material RimsBrand:Polo Interior lighting Blue neon bars under and around dash Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED) http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg http://www.dcsoundlab.com/images/header.jpg
Marlo Stanfield Posted December 5, 2009 Report Posted December 5, 2009 Ok i am thinking about making a box for my Rockford Fosgate 12" Hx2 sub.I was going to make the box measurements out by Length=20 depth 30" Height 15" so i went online to the online box demensions calculater and i put in the measurementsit came out to be a 4 cubic feet all together.Thats the exact demensions the Hx2 needs.Now my qeustion is what kind of port should i do for this box so i can tune it to the right hurts.A circular port,|===|<---or the port that looks like that.Or should i do the removable like steve meades port on his tahoe box so i can swicth out different sizes.I posted this because i needed some feed back and help so i do not screw up this build and i know you guys are bluntly honest so can you help me out??This will be my first build ever.Does any one have any good information??? . I loled at "the right hurts", it's spelled hertz just to let u know. What Hx2 do u have, power or punch?? What kind of power are u running?? Daily or SPL setup?? These need to be answered before we can give u any box specs to base a design off of. After wood displacement(using 3/4" wood + no double baffle) = 4.6ft3 gross that you have to work with. As far as ports are concerned, I wouldn't suggest doing a removable port. It's a pain in the ass IMO and will just be much more work than I'm guessing you'd want to put into this small of a setup. I'd suggest just a standard slot port and if u wanna make it a lil different than other slot ports, just kerf the port. It will allow a lil better airflow plus it just looks a lot cooler than a standard slot does. Also could use aero ports like 2-3 4" ports or a single 6". They will require less port area than a slot will, allows a lil better air flow than slot ports do(also get a little louder), and they can be adjusted if you use ones like PSP sells. You can just adjust what length the ports are, to get the tuning you're looking for by just taping the middle piece in place. But answer the questions at the top first and we'll go from there. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Rydaz1Bass Posted December 5, 2009 Author Report Posted December 5, 2009 I loled at "the right hurts", it's spelled hertz just to let u know. What Hx2 do u have, power or punch?? What kind of power are u running?? Daily or SPL setup?? These need to be answered before we can give u any box specs to base a design off of.After wood displacement(using 3/4" wood + no double baffle) = 4.6ft3 gross that you have to work with. As far as ports are concerned, I wouldn't suggest doing a removable port. It's a pain in the ass IMO and will just be much more work than I'm guessing you'd want to put into this small of a setup. I'd suggest just a standard slot port and if u wanna make it a lil different than other slot ports, just kerf the port. It will allow a lil better airflow plus it just looks a lot cooler than a standard slot does. Also could use aero ports like 2-3 4" ports or a single 6". They will require less port area than a slot will, allows a lil better air flow than slot ports do(also get a little louder), and they can be adjusted if you use ones like PSP sells. You can just adjust what length the ports are, to get the tuning you're looking for by just taping the middle piece in place. But answer the questions at the top first and we'll go from there. I have the punch and yes i noticed i spelled hertz wrong i was in a hurry lol and its the 12" woofer I am working with a 600 watt kenwood amp.But i might buy two more same type more powerful amps to run what i need to run VehicleCurrentlyOwned:2000Malibu \/MySystem\/ Ken-Wood HeadUnit Cars interior panels Custom blue Done by ME Pheonix Power block running both amps Stinger pro series four gauge wire flex material RimsBrand:Polo Interior lighting Blue neon bars under and around dash Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED) http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg http://www.dcsoundlab.com/images/header.jpg
Marlo Stanfield Posted December 5, 2009 Report Posted December 5, 2009 I have the punch and yes i noticed i spelled hertz wrong i was in a hurry lol and its the 12" woofer Ok thanks for answering the other two ?s i put down so that we could help u out. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
93TurboDsm Posted December 5, 2009 Report Posted December 5, 2009 yeah like how much power your working with< rms on your amp and do you want spl or sq (1) RE MT 18" (2) Orions D5000s (1) Fiamm 500 flx 12 agm batt
