So this morning I crank the car up and heard a real loud popping sound. Open the trunk and the bass amp is smoking. My highs amp runs fine. Does anybody know what could have caused this. Thanks
fet's prob. blew up. if its not under warrenty, open it up and check it out.
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
do u shut off the headunit befor u turn off the ignition key?
that could do it cause most ppl just leave there stereo on n up were they had it the day befor n when they get in there in the moring n it starts up n starts wangin all of a sudded could do it
im not saying thats what caused it but it could be a idea to throw in there
and what kinda amp is it that ur running so we can give an example as if ur electrical is good enough for it?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
wiring, electrical, heat, there are lots of things. I wouldnt open it cause it might void your warrenty.
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
Naw I dont do that and the radio was on 7/ 62 and the amp I am talking about is the kicker 1500 and my electrical consist of a yellow top starting batt big 3 in tsunami 0 gauge wiring. The amp had 0 gauge kicker power and ground and mechman 220 amp alt
Edited by thegreat22
doesnt sound like electrical..Id check your wires for any shorts. Is the amp mounted to your sub box?
Edited by barros57
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
Tell your amp that smokin' cause cancer and it should get help right away!
:D
J/k. Something on the board probably blew. Get us some pics of the inside (if you open it up).
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
oh ya i forgot
what do u have wired to the amp?
and what ohm load?
i think the kx1500.1 is a 2ohm stable amp
http://www.woofersetc.com/p4190/ZX15001--K...s-Amplifier.htm
ya 2ohm stable, if u had it wired to 1ohm that could be ur problem right there, i kno ppl have ran these at lower than 2ohm loads n it be fine but u never kno, theres always that variable in everything
and make sure ur speaker wires aint shorted at amp or power n ground wires frayed out at terminals
and make sure u have a good ground at the amp
and was it working good yesterday?
oh ya i forgot
and what ohm load?
what he said. ^^ yea, check to see what ohm load your amp is seeing.
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
