I need help on a navi install
Ok I am having problems finding the speed sensor wire on this thing can some one tell me where to look online or if you know please tell me what color it is and how to get to it thanks guys. Its a 2001 Lexus GS 300
its a solid blue wire i looked it up at work im a master tech for toyota,this is the wire that goes to the stock navi system i asume thats what you want
my bad it loks blue in the book but its actually violet
should be in the fatory radio harness.
or it's gonna be at the ecu.
this might help but its for a 2000
2000 Lexus GS300/400 Cruise Control Wiring Information
Constant 12V+ White/Blue Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black/Yellow Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Driver's Kick Panel in 20 Pin Connector
Cold Side of Brake Green/White Driver's Kick Panel in 20 Pin Connector
Tach Black/Yellow Module under Hood Driver's Side 28 Pin Connector Pin16
VSS Wire Blue/Yellow Pin 5 Connector E4 in Black Box Driver's Side of ENG
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
01 Tahoe
Big 3
20 ft.1/0 streetwire under hood
4 Batteries
Stock Battery and
1800 Kinetic Batt under hood
2 Sprinter S12V500F Battery,165 AH
Kicker 1/0 going from front to back
Sirius sportster
Alpine 9886
Kicker 650.4zx mids and highs
Q-Logic kick panels w/Kicker6 1/2 comps.
XXX re comp 6.5 in front doors
Alpine6.5 coax in rear doors
2 Audioque 2200d strapped
2 Audioque 18 HDC3
5% all the way around
2 layers raamat on roof
doors covered in raamat
  • Who's Online   0 Members, 0 Anonymous, 1424 Guests (See full list)
