xp install problems, gateway laptop
Yes , its very easy. Basically your OS disc does not have the sata drivers needed to install XP. If you had the original gateway discs you could easily install it without any problems.
So heres how you fix it... Go to gateways website and download the correct sata driver for your laptop and put it on a floppy disc (yes a floppy disc!)
I am assuming your laptop does not have a floppy disc drive so you will need to find a USB floppy drive to plug in. So put the floppy disc in the drive then plug it into your laptop.
Now start installing the OS and when at the bottom it says “Press F6 if you need to install a third party SCSI or RAID driver…” press F6 and then go from there, if you have downloaded the correct driver from gateway it will work. You will now be able to complete your windows installation.
Its really easy , be patient and keep us updated
Too Much Stuff to list .
Also to make sure all the drivers are correctly installed go to my computer, right click and go to the
properties and then go to hardware tab, and then click on device manager and make sure you see no
yellow queston marks.
2003 Mercury Marauder Black (R.I.P)
Tinted Windows
Purple HID's 10000K
Fog Light HID's 10000K
Swi Jack Steering Wheel Controls
Apple I-Pod Classic 80GB
Alpine KCE-422i Full Speed I-Pod Cable
Alpine IVA-W203/P1 Navigation/Bluetooth
Alpine PKG-M780 7' Headrest Screens
Alpine PXA-H701 Sound Processor
Alpine MRP-F300 4 Channel Amp
Rockford Fosgate 1501bd Power Amp
2 Kicker L7 15' Solo Barics
Alpine Type R SPR-17S Component's
Alpine Type R SPR-57C Coaxial's
Monster Performance RCA's
0/2 Gauge Wires
BIG III W/Fuse
200 Amps Custom Built Alternator
Yellow Cap Optima Battery Front
Xstatic Batcap 800 Back
Custom Mounted Bass Knob
LED's 2x License & Trunk Light
BoYo VTK-350 Color Backup Camera
Dynamat Xtreme Front Doors & Rear Deck
Clifford Matrix 50.7X Alarm System/Remote Start
  • Who's Online   0 Members, 0 Anonymous, 1014 Guests (See full list)
