fi audio Posted December 10, 2009 Report Posted December 10, 2009 Well i think in feb-march ill be doing a blowthrough in my single cab. With 300 amp iraggi altenator, 2 fi btl 18s fully loaded, 2 audioque 2200d's. Im just kinda putting together a list of stuff i need, the stuff im unsure about is how many batterys will i need, should i run 1 aq 2200d to each sub at 1 ohm or should i strap them for 2 ohms, also what would you think would be the best to tune the box to? its going to be a daily driver Setup: Headunit: 7" indash screen Sub: fi bl 12 Amp: Audioque 1200D Box Ported tuned to 34hz Big 3 done in 1/0 gauge
brewer_brewer Posted December 10, 2009 Report Posted December 10, 2009 get 2 dual 2 ohm btl's and strap the amps. will get more efficient power. as far as batterys i would say 3 or 4 big batteries would be fine for a starting point something like kinetik 2400 or similiar REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
steven Posted December 10, 2009 Report Posted December 10, 2009 get 2 dual 2 ohm btl's and strap the amps.will get more efficient power. as far as batterys i would say 3 or 4 big batteries would be fine for a starting point something like kinetik 2400 or similiar x2 the kinetik 2400's have done great for me...
fi audio Posted December 10, 2009 Author Report Posted December 10, 2009 x2 the kinetik 2400's have done great for me... dang i see you have like the same set up have you had it on the tl? Setup: Headunit: 7" indash screen Sub: fi bl 12 Amp: Audioque 1200D Box Ported tuned to 34hz Big 3 done in 1/0 gauge
steven Posted December 10, 2009 Report Posted December 10, 2009 dang i see you have like the same set up have you had it on the tl? Honetly I have not metered yet, the shop in which i will test it is a few hours drive for me. I finished up school today so I'll probably get it metered within the next couple weeks with a video too...
steven Posted December 10, 2009 Report Posted December 10, 2009 dang i see you have like the same set up have you had it on the tl? ps get at LEAST 3 batteries
fi audio Posted December 10, 2009 Author Report Posted December 10, 2009 ps get at LEAST 3 batteries ok they have to be atleast 2600amps or higher or can they be like the kinetic 1400 which is 1500 amps and have 3 of them? Setup: Headunit: 7" indash screen Sub: fi bl 12 Amp: Audioque 1200D Box Ported tuned to 34hz Big 3 done in 1/0 gauge
steven Posted December 10, 2009 Report Posted December 10, 2009 ok they have to be atleast 2600amps or higher or can they be like the kinetic 1400 which is 1500 amps and have 3 of them? I would go bigger than the 1400's you'll need quite a few going with smaller batteries. I would just get bigger ones its better than a ton of smaller ones imo...
fi audio Posted December 10, 2009 Author Report Posted December 10, 2009 I would go bigger than the 1400's you'll need quite a few going with smaller batteries. I would just get bigger ones its better than a ton of smaller ones imo... yea i guess that would be the best bet i think if im going to spend that money though im going with xs power lol Setup: Headunit: 7" indash screen Sub: fi bl 12 Amp: Audioque 1200D Box Ported tuned to 34hz Big 3 done in 1/0 gauge
