ok guys i know i posted a thread like this a while ago but my truck is gonna be stripped in the back for this install very soon. anyways i will be running a TREO SSp 1000w rms woofer. it will be going in a downfire enclosure that i think i'm going to port (don't know if i will run the port to the floor or out the side) but may seal it...not sure yet. my question is if i do decide to port what should i tune the port to?
the box will be around 1.25 cubes and i'll be running 1000 watts to it - if i get the 10"
the box will be around 1.75 cubes and 1000 watts - if i get the 12"
can you give me any ideas for any of this info for either size of sub as i'm still undecided on which one i'll be getting
if you need anymore info to help me figure this out just ask
is this a prefab box?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
anyone?
Dont face it down, that will suffocate the port unless it has like over 6'' from the port opening to the floor. I had a downfire in my silverado for a little while, it was a crappy prefab but I used a hole cutter and put a 2'' pvc port in each side of the box firing out towards the doors and it sounded pretty decent, I had like 8'' on each side between the port and the door though. You will probably get your best results if you fire it foward toward the front seats.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
would that give the port anything to "load" off of though? i see what you're sayin about facin it to the floor...but if i built the box for the sub and use the right port area and all that it it should sound good porting out the side or forward? i just want it to BUMP but still sound good
Yea it wll sound much better to the side or foward because the floor would obstruct your airflow of the port
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
  • Who's Online   0 Members, 0 Anonymous, 5172 Guests (See full list)
