Fi Car Audio
im planning the get a 12" bl here in the next couple months. i was wondering if a alpine mrp-m1000 is enough to power the bl on stock alt and everything? i know the alpine is rated 1,000watts rms at 2 ohm but says unstable at 1 ohm
hqvnt used alpine amps but arent the bls rated at 1500? or is it 1000?
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
i thought they were rated 1000 but i could be wrong ill go check again
just checked it says 1000
Edited by sloenuf
well i f that alpine puts out rated it should be fine, get the dule 1's and wire u to 2ohms. thats if the amp puts out rated power. like i said i never used it beore. if not a believe an audioque 1200D is only around 250 or 300
New Project
[top secret]
whats the difference between doing that and getting the dual 2 ohm?
duel 2's can not be wired to 2 ohms on one amp. each coil has its own impedence. you can wire duel 2's to either 1 ohm or 4 ohm, or you can wire duel 1's to either half ohm or 2 ohm. look up the rockford wiring wizard if you need help with thid. they explsin it bette than me
New Project
[top secret]
ok thanks.
a dual 1 ohm woofer can be wired in parallel to .5 ohms or in series to 2 ohms.
dual 2 woofer is 1 ohm in parallel and 4 in series
beat you! lol, and no problem just remember. a dule voice coil woofer has 2 coils so you have to account for that when choosing wich one to use on your amp
New Project
[top secret]
That MRP-M1000 will put out the rated power at 2 ohms.
new car in the works.
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
