wire the mids on 1 and 2 individually...then wire 2 sets of tweets to 3 and 4 in parallel.
Eclipse cd7000
connect left mid to channel 1....connect rigt mid to channel 2...
connect LEFT two tweeters to channel three....put both tweeter positives in +...put both tweeter negatives in -
connect RIGHT two tweeters to channel 4.......put both tweeter positives in +...put both tweeter negatives in -
Edited by finkster
Eclipse cd7000
I have to run for a little bit. I'll be back if you still need help just hold tight or wait for someone else :D
good luck mane. also you have to make sure you set your filters right for this to work well :)
Edited by finkster
Eclipse cd7000
If you are referring to RCAs, then all LEFT inputs (white) will go to 1 and three.
all right inputs (red) will go to channels 2 and 4.
so you will need 2 RCA cables...2 red and 2 white.
EDIT: if someone has a better idea to wire them then post them up :)
gotta run...later
Edited by finkster
Eclipse cd7000
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
