Wiring Mids and two sets of tweets to one amp
connect left mid to channel 1....connect rigt mid to channel 2...
connect LEFT two tweeters to channel three....put both tweeter positives in +...put both tweeter negatives in -
connect RIGHT two tweeters to channel 4.......put both tweeter positives in +...put both tweeter negatives in -
Edited by finkster
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
I have to run for a little bit. I'll be back if you still need help just hold tight or wait for someone else :D
good luck mane. also you have to make sure you set your filters right for this to work well :)
Edited by finkster
Eclipse cd7000
If you are referring to RCAs, then all LEFT inputs (white) will go to 1 and three.
all right inputs (red) will go to channels 2 and 4.
so you will need 2 RCA cables...2 red and 2 white.
EDIT: if someone has a better idea to wire them then post them up :)
gotta run...later
Edited by finkster
Eclipse cd7000
  • Who's Online   1 Member, 0 Anonymous, 688 Guests (See full list)
