Dont Bore a Hole in the side of you sealed box and think you have a ported box now.
This was my buddys "Ported" Box, before I hooked him up with an actual ported box for his subs.
¿ǝɯɐƃ ǝɥʇ
t'was joking :friends:
sealed boxes can beat hard but they're low-end lacks. (not saying its absent lol).
if you design them right and have a qtc of .7 or so then itll sound great and beat.
Dont listen to this guy ^^
sealed box's have great low end just need the right amount of subs and a proper sealed box none of that prefabed shit
look at how many Loud bassracers out there that have/had sealed box's
R.I.P!
(Nov-29-2009)
92 explorer
current build
i never said they werent loud. i said their low end lacked on paper. the response level is normally an upsidown U from all the times ive played around with sealed boxes.
anyways
Take your main fuse out before you do anything. It will save you a couple of bucks and trips to the local car audio shop.. and it will keep you from screaming oh fuck whenever you touch your power wire to something it's not supposed to be touched to haha
How about trying to just disconnect the main battery its alot safer
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
do not hook up just one coil of a DVC sub
Kicker claims the same, but as long as you only run half the power then you can run only one coil.
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
lol thats funny
Dont be afraid to fail. We've all done it (some will admit it before others) Dont be afraid to ask questions. and DO learn from your mistakes. (burn up an amp and you'll know what I mean)
  • Who's Online   1 Member, 0 Anonymous, 1223 Guests (See full list)
