Subs Wiring(need Help Asap)
heres a pic of what i drew the top two subs are the ones i have and the drawing below it is the subs i might buy how do i have the subs on top wired and can i wire the ones on the bottom the same
Edited by white_boi_audio
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
no one can help me
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
You would wire it the same but with out the DVC. pos to pos and neg to neg. If the woffers are 2ohm subs then it would drop the load on the amp down to 1ohm.
SMDsigbannr4.jpg-
yes you can if ur amp is stable at 2 ohms cause that way there wired down to 2 ohms, but the way u have the dual 4 ohms wired up is at jus 4 ohm when you can take them all the way down to 1 ohm. but what really mater is what kind of amp is u running a 1 ohm stable or 2 ohm stable.
rims.jpg2 12" Kicker cvx1 proacoustic 4 now either quantum audio amp r Ma audio nextKenwood dash4 gauge wire pioneer in the doorsjvc in the back
http://www.electronixwarehouse.com/car/sgl...mpro/vs1405.htm
heres my amp and my bad on the drawing the subs on the bottom are actually single 4 ohms and if i wire them down to 2 ohms or even 1 ohm if my amp can do that. would they get more power meaning hit a hell alot harder
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
can my amp be wired down to 2 ohms right now i have my subs wired at 4 ohms if i can wire them to 2 ohms will they hit harder than they already do?
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
anyone got any suggestions or can someone please tell me what to do or if i can do what i asked earlier i am probably going to change the wiring tomorrow?
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
If those are dual 4 ohm subs, then you cant get 2 ohms. It would definately hit harder if you had it at two ohms, but you can only hit 1 or 4
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
so is there anyway i can wire them subs to one ohm without my amp going into protection if my amp is able to do that 1 ohms stable did u look at the link for my amp specs
doesnt 1x600 isnt that 1 ohm or what
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
hey yo sean where u at dude
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
  • Who's Online   0 Members, 0 Anonymous, 572 Guests (See full list)
