Im going to be installing an XS Power S3400 in the front of my Silverado soon. I want it clean and professional looking.
I want to see some picts of some of the members installs here to see what your doing and possibly get some good ideas for my truck.
I will have the big 3 connected to it and the factory wiring connected to the side with an Ibar adapter. I might be getting a 555 adapter to make all the connections a little easier. I will have 2 positive runs and 2 negative runs to the rear bank of 3 D3400's.
I plan on using ring terminals for all the battery connections.
Right now I would just like some pictures of some bad ass battery and wire installs.
Thats what im talking about. I like the look of that setup. That KNU wire looks like it bends like a wet noodle.
Oh yea, that Knu is awesome to work with. Its the kolosssus fleks cable. The bars are 3/8" x 1.5" copper from www.mcmaster.com drilled and tapped for 5/16 - 20.
97 Maxima SE
Bunch of shit going in, check out the build
How you connect that connector to the battery. I don't see a clamp or battry connector. But it's awesome.
The front most bolt goes right into the battery terminal, that one hole is just drilled, not tapped.
97 Maxima SE
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
Nice, I like the bends. How did you make those?
I am not 100% sure, our Team captain made the bars for me. I just bought the materials and let him at it. I would assume he used a vise and just bent it over. If you want to know PM kandiman71874.....
