Im kind of on a budget and need more power. I am not a fan of running dual batterys so could i replace the stock batt. with an XS and would it run the car and system alright?
1995 Integra GSR (DB8)
Pioneer 3200-DVD
6.5 rockford fosgate 2-way fronts
6.5 rockford fosgate 3-way rear
saz-3000D
(2) 12" SA-12s
Depends on your budget, stock battery size and how big of a system youre pushing...
not very big jus 750rms, but im wondering if it would be safe to run an XS batt. like if the stock batt. is 640a and the XS is 1000, does that matter?
Pioneer 3200-DVD
saz-3000D
(2) 12" SA-12s
It means more power for your system :) Perfectly safe.. Which batt are you considering, d680?
yea thats what i was thinking, it said it could support 1000watts.
Pioneer 3200-DVD
saz-3000D
(2) 12" SA-12s
Yeah do the big 3 and add the 680 youll be fine with just 750 watts
On the Big 3 charge wire, should I leave the stock charge on the alt. bc I have no idea where the other end runs 2 and i herd it may have 2 stay on. Thats the only part i dont understand on the big 3.
Pioneer 3200-DVD
saz-3000D
(2) 12" SA-12s
You just add the bigger wire along with the stock wire. By "charge" wire i assume you mean from alt to batt +
correct so all the stock wire can be left alone?
Pioneer 3200-DVD
saz-3000D
(2) 12" SA-12s
