well on my pt looser i have 2 pos cables from pos side of batt. one to alt one to starter. should i just do the alt side or both.
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
alt to battery. batt to chasis. batt to engine
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
so jus leave the starter one alone.. alrighty thanks..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
yup np
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
i dont see why you shouldnt do the starter also. more current for starting ftw
That is true- it couldn't really hurt, especially if you have the spare wire. If you do it though, it needs to be fused as well. It won't help your charging any, but it would make life a bit easier on your starter.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
well i started to go through it. but the power from the batt goes to the distrobution block, and then to the alt.
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
for the batt to engine block, do you just find a bolt on the engine block and put the ring terminal on that?
no. the pos goes from batt, to distribution block, then to alternator.
should i just go from distribution block or
should i do both of them.
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
Just go from battery straight to alt
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
  • Who's Online   0 Members, 1 Anonymous (See full list)
