99xtremedime Posted January 4, 2010 Report Share Posted January 4, 2010 Ok I decided to give up on having someone else design my box for my new set up, and do it myself. This is my first time doing this and I am highly relying on box calculators/tuning calcs. So I measured my rear cab and came up with the largest box I'd wanna go with (46"W x 27"H x 15"D). On the RE's calc with the box tuned right at 33hz it says 7.554cuft, but then I typed all the same demensions into exosports calc, including woofer diplacement it says 7.36 net at 30hz which gives me around 8.28cuft gross. Is RE's calc just shit or is exosports just more accurate? -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted January 4, 2010 Report Share Posted January 4, 2010 Expo's calc is a lot better... Just rely on that if you're planning on using a box calc. If you want a good design from a member on here then you're more than likely gonna have to pay for it. Accordman does some good designs from what I've seen and is pretty reasonable with pricing. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
k3n12ock Posted January 4, 2010 Report Share Posted January 4, 2010 Nightshade and footlongsam both design nice boxes as well. 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
99xtremedime Posted January 4, 2010 Author Report Share Posted January 4, 2010 yeah ill probably end up doing that, i need someone to design it that knows what they are doing and how to build a box for my sound needs.. lol. I gave up on the last guy because he wanted to do it his way, swore i couldnt do 1 18 or 2 15's without a wall or blowthrough. -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
