Marlo Stanfield Posted January 5, 2010 Report Share Posted January 5, 2010 5.5-6ft3 @ 34hz w/ 70-80in^2 of port area per pair of woofers is my box suggestion. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
UMGixxer Posted January 5, 2010 Author Report Share Posted January 5, 2010 5.5-6ft3 @ 34hz w/ 70-80in^2 of port area per pair of woofers is my box suggestion. how does the port area affect the system, bc u can still tune the box wit a lower port area Quote Link to comment Share on other sites More sharing options...
UMGixxer Posted January 6, 2010 Author Report Share Posted January 6, 2010 ??? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 6, 2010 Report Share Posted January 6, 2010 the less port area you have, the easier it is to tune low. BUUUT you run the risk of having port noise which is super annoying and sounds like balls. the more port area you have (always aim for 12-16sqin per cubic foot), its a little harder to tune lower but the performance is better as far as moving air around. Quote Link to comment Share on other sites More sharing options...
UMGixxer Posted January 6, 2010 Author Report Share Posted January 6, 2010 the less port area you have, the easier it is to tune low. BUUUT you run the risk of having port noise which is super annoying and sounds like balls.the more port area you have (always aim for 12-16sqin per cubic foot), its a little harder to tune lower but the performance is better as far as moving air around. how is it harder to tune? Quote Link to comment Share on other sites More sharing options...
UMGixxer Posted January 6, 2010 Author Report Share Posted January 6, 2010 the less port area you have, the easier it is to tune low. BUUUT you run the risk of having port noise which is super annoying and sounds like balls.the more port area you have (always aim for 12-16sqin per cubic foot), its a little harder to tune lower but the performance is better as far as moving air around. do you use this rule for the gross volume or the net volume Quote Link to comment Share on other sites More sharing options...
