Fi Car Audio
What advantages does a fully loaded btl have over a reg. btl? Is fully loaded for SPL only? Why does one need to be fully loaded?
EDITED**
Edited by Boomzilla
2004 Ford Explorer
2x Soundstream Tarantula DTR1.3400D(3400Watts RMS @half ohm each)
2x Fi SP4 18"
0 Gauge(aquired)
Mechman 270Amp alternator
4x Kinetik2400(Needs starting battery)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
I miss worded my question, I ment what does a fully loaded BTL have over a non-loaded BTL?
2004 Ford Explorer
2x Fi SP4 18"
0 Gauge(aquired)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
i believe you would not want a fully loaded btl for high spl applications... such as a burp or fart box. If you read on fi forum they have what options to go with if you are looking for the most power handing... Such as i belive you would not want the extra cooling if you are using it for an spl application due to the fact it weakens the sub motor structure.... fi forum would be a great tool of info for this question.
Edited by NotoriouslyLoud
Sub SQ is a lot more forgiving than mids/highs, as there is no imaging or staging. Basically a sub has to be precise and have a flat response curve...and 90% of that is in the box. So you can make just about any sub sound good, and a nice sub sound shitty.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Well I am going to run a goliath on 2 18" BTL's and wasn't sure if I needed them fully loaded or not.
2004 Ford Explorer
2x Fi SP4 18"
0 Gauge(aquired)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
no you will not... i am running the same set up in an astro van... and i got dual 1 with cooling (for daily use) 3rd magnet, HiXmCoil and got the daily option
they are some beast bro you will be happy with them... shit i have not even heard mine yet (got it yesterday) and i am happy as hell... and when you see one up close you know it will not have a problem with a goliath :D
Grats on the subs! Let me know how it sounds when you get it rumbling. :rolleyes:
2004 Ford Explorer
2x Fi SP4 18"
0 Gauge(aquired)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
