Jextel Posted January 7, 2010 Report Posted January 7, 2010 could it be a bad output from the alarm or siren? the sirens stopped when i drove thru some high water BTW my car is lowered and the siren sits pretty low in my engine bay Quote http://www.cardomain.com/ride/3042878TEAM DEADLY HERTZ "GET LOUD OR DIE TRYIN"only the loudest will survive.
jack Posted January 7, 2010 Report Posted January 7, 2010 no chirps or anything. is the siren in a position to drain. you can use a dmm and check for voltage accross the red and black wires at the siren itself when you arm/disarm. or just put it into panic mode. if you dont have a dmm ir test light... just cut the red wire and run a lead from the siren to the positive post of the battery. also check your ground. Quote http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build" (1) DC AUDIO Level4XL 10 (2) PowermasterD2700 batteries ALL FOR SALE TEAM DC AUDIO TEAM DIRTFLOORPOOR
