Incriminator Audio Warden series
I am still a lil skeptical about these....
I want to see some more numbers.
What will these subs take DAILY rms wise? 4-5k ?!?!
If they are the shiznit, I may be picking up 4 18's along with the new TSNS's
Daily... A guy I know is running 8kw daily to each one of his 15's. Bout to be 15kw daily. He was doin 158.9. About to be doing 160+. In a cavalier.
2004 Mustang
3 18s
6 crossfire bmf 1700s strapped @ .5
161.2 db Daily driver
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
http://www.youtube.com/Drek75633
That Beajay's Cavy with the 4 15s walled off + Stetsom amps... On paper he might be running like 7-8kw per woofer, but clamped power I can assure you is no where near that amount. Also I'm like pretty sure that his 158+ score was done with one of the doors open, not saying the score still isn't impressive either way though.
I did a few tests with one of these a few weeks back.. In testing a 15" Warden was .2db less than my 9515G on an AB 400.1 + 500.1.. Once I stepped up the power to a 700.1 I picked up a .1db increase and on a 10k burp it was up to .4db over the DD. These were all burps scores in like the 4-5 hours of testing I had available to me to play with the Warden. If I had more time I would've done some testing on music and maybe of tried a few different burp boxes I had.
Pioneer AVIC-N2
That's some nice info bro. If you know anything more. Pm me and let me know.
2004 Mustang
3 18s
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
I was standing next to car in that video. Yes driver's door was open(hardcore). I'm not sure on the exact clamped power but it was quite a bit less than what the amps are rated at.
TDH FTW !!!
He does it to prevent distortion and clipping I think. He is most likely doing 4 kw maybe 5kw to each sub. He has all 4 stetsoms now. So he will probably be clamped at 10kw per sub.
2004 Mustang
3 18s
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
Ya, I will have anywhere from 4k to 8k per driver in my wall with 4 18's. So subs are going to be put through hell... may just still end up with HW's
get at my brother who has 2 21 wardens with 4 20.1s daily, doin 156.
4 I.A. Warden 15s
8 I.A. 20.1s
2010 140.0-149.9 Bass Race Points Champ/Over all champ
2010 140.0-149.9 Bass Race S.C. Regional Champ
2010 FL Regional Middle Weight Champ
2010 INAC Middle Weight Bass Boxing Champ
only issue Ive got with that vid is it looks like the door may have been open during the run which if that was the case possably gave him a few DBs
nor can you see mic placement
4 I.A. Warden 15s
8 I.A. 20.1s
Me and Beajay have been brainstormin over how my set up is goin to be. Point me out to your brother. I would like to talk to him too.
2004 Mustang
3 18s
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
  • Who's Online   1 Member, 0 Anonymous, 1509 Guests (See full list)
