so i have a go-cart frame i ordered some parts that i needed
now i got the smart idea of putting some lights on it i might just use some yellow foggers that i have but its a go-cart how do i power the lights i want them to last at least 4 hours if its powered by batterys and i have a limited amount of space i wanna use the least space as possible i need help thanks you guys
2 jl audio 12w3's sealed
soon to be 4 level 3 15's
blow through
all dc audio
your gonna need to get a stator that charges. idk if your motor will allow that if not put a battery on it with a switch and youll have to charge it
engine with stator is best. btu a small kinetic or similar brand battery should do great for space. just remember that the amp draw of the lights will determine battery life.
how long do you think that a kinetics 600watt 12v battery will power 50watt light
blow through
all dc audio
How many lights? You would just take the AH rating on the battery and then apply 20 hours to it... Sooooo a battery with a 30 AH rating can supply 30 amps of power for 20 hours before dropping to 10.5... So if you have bulbs that pull 3.5-4 amps of current.. It's a looooooooooooong time brother.
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
how bout LEDs know where i can get some magnetic ones
blow through
all dc audio
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
