Electrical questions?
So i'm totally new to car audio, i've already learned alot form everyone on here, but my quetion is If i had 2 15 inch rocksford power serious t2 subs, with 8 tweeters and 8 mids, and t 1500 1 channel amp and 2 t 400 4 channel amps, would the big 3, a high output altenator, and an extra batterie in the back be enough to power all that along with an upgraded batterie up front? Or would i need 2 batteries in the back, and if i did need multiple batteries in the back how would i wire them all together with the front batterie, then wire the amps to the back batteries? Also how do i wire multiple rcas up to a deck, if i had 2 amps for the subs and 2 amps for the mids and highs? Same with the remote sterio wires?
thanks everyone i could really use help cause i'm new and i'm trying to plan out what system i'd like
Thanks,
Ryan k.
2001 Dodge Ram
Amperage on the alternator? Size batteries? VC configurations? Total RMS power output?
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
a 200+ amp alt would make things run smoother. along with a solid battery up front. BIG 3 a must.
those chevys have a lot of room up front so just run a good one and i dont see the need for another in the back unless you plan on running more power in the future. But it sounds like you are off to a good start.
Eclipse cd7000
Thanks man, i think i might just add another batterie in the back for extra security, becuase i'll be running 4 amps so i dont want to run that all off one batterie.
2001 Dodge Ram
  • Who's Online   0 Members, 0 Anonymous, 1116 Guests (See full list)
