Chrisn077 Posted January 22, 2010 Report Share Posted January 22, 2010 My amp keeps cutting in and out when i turn it up. When its barely on it doesnt do this but its not hitting at all. And fuses blow if i turn it up and let it cut in and out too long. Ive been looking around for similar problems and it seems like its a voltage problem. I have the Big 3, 0 gauge, but no battery in back, I was told I wouldnt need one with only 1500 rms. Im running 2 12" alpine type r on a AP300.0 (bridged to 1500 at 1 ohm) 18" DC Level 4 Link to comment Share on other sites More sharing options...
Tooshort064 Posted January 22, 2010 Report Share Posted January 22, 2010 what kind of fuse holder do you have ? also check your grounds! 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc. Link to comment Share on other sites More sharing options...
Chrisn077 Posted January 22, 2010 Author Report Share Posted January 22, 2010 i checked my ground its pretty tight on there and has a good connection from the looks. I havea audiopipe 150a fuse & holder. 18" DC Level 4 Link to comment Share on other sites More sharing options...
Chrisn077 Posted January 22, 2010 Author Report Share Posted January 22, 2010 its a 100a fuse i have some 250a fuses laying around should i put that in 18" DC Level 4 Link to comment Share on other sites More sharing options...
Chrisn077 Posted January 22, 2010 Author Report Share Posted January 22, 2010 anyone 18" DC Level 4 Link to comment Share on other sites More sharing options...
Loudcivic Posted January 22, 2010 Report Share Posted January 22, 2010 My amp keeps cutting in and out when i turn it up. When its barely on it doesnt do this but its not hitting at all. And fuses blow if i turn it up and let it cut in and out too long. Ive been looking around for similar problems and it seems like its a voltage problem. I have the Big 3, 0 gauge, but no battery in back, I was told I wouldnt need one with only 1500 rms.Im running 2 12" alpine type r on a AP300.0 (bridged to 1500 at 1 ohm) do you mean you have an ap3000d. if so that amp is not stable at 1 ohm bridged . it is 2 ap1500's internally bridge and can only operate at 2 ohms bridged. if thats not the amp you have then my bad 2015 silverado crew cab nothing atm but soon... Link to comment Share on other sites More sharing options...
Chrisn077 Posted January 28, 2010 Author Report Share Posted January 28, 2010 No its a 300.2 and does 1500 @ 1 ohm bridged. Can someone please help me 18" DC Level 4 Link to comment Share on other sites More sharing options...
Guest Posted January 28, 2010 Report Share Posted January 28, 2010 i wouldnt use a smaller fuse than recommended for that amp. that is 99% of the reason why your fuses keep blowing and the amp keeps cutting in and out. but for your grounds, is all of the paint on the metal that the lug is bolted down to cleaned off? meaning a shiny piece of metal is touching 100% of the lug. Link to comment Share on other sites More sharing options...
Mtgrooves Posted January 28, 2010 Report Share Posted January 28, 2010 never seen a ap 300.2 in fact neither has audio pipe according to there web site and google The Shoe Maker without shoes! Link to comment Share on other sites More sharing options...
Chrisn077 Posted January 28, 2010 Author Report Share Posted January 28, 2010 well it says audiopipe and then under neath that is says 300.2 and above audiopipe it says 1500. But its not the mono i guess its just a AP1500 instead of a AP1500D..I dont know. 18" DC Level 4 Link to comment Share on other sites More sharing options...
