BeachJoshua Posted January 24, 2010 Author Report Posted January 24, 2010 i moved hair with 250rms and a single 12 not alot tho but it was movein Will 4 Kicker Comp 12's in an S10 move any hair? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
Guest Posted January 24, 2010 Report Posted January 24, 2010 Will 4 Kicker Comp 12's in an S10 move any hair? build it and find out. no way to tell you
BeachJoshua Posted January 24, 2010 Author Report Posted January 24, 2010 build it and find out. no way to tell you Oh trust me, I'm gonna build it. | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
wakerider1533 Posted January 24, 2010 Report Posted January 24, 2010 Hh yes you can deff move some hair in an s dime.. I had 3 l7 12s foe my first system snd it did some hella hair tricks.. I'd say port size would be the biggest factor with my experiance anyways '06 Mustang GT 5spd Sundown X10 Sundown SAE 1500.1 Optima Yellow Top D31 Pioneer 7'
abervintageman42 Posted January 24, 2010 Report Posted January 24, 2010 low tuning and its not about the shape of the port, its more of port area, so low tuning, port area, cone area and vehicle are the main factors
tyler_da_bass_playa Posted January 24, 2010 Report Posted January 24, 2010 I dono, I'm not sure I understand the idea of building a system based on creating a hair trick. Unless your a huge fan of showing off, but hey whatever floats your boat. I think stereos for an everyday driver should be based around what sounds good to YOU, and not base it on how good it makes that girls hair feel in the wind :hairtrick: . Good luck though!
arnold1992 Posted January 24, 2010 Report Posted January 24, 2010 sound pressure moves air and hair RE se xxx 18d2 (4) Audioque 2200 (2) DC Power 270XP blue 3 C&D fr310 Stinger wiring CDT components
fritosaregood Posted January 24, 2010 Report Posted January 24, 2010 I dono, I'm not sure I understand the idea of building a system based on creating a hair trick. Unless your a huge fan of showing off, but hey whatever floats your boat. I think stereos for an everyday driver should be based around what sounds good to YOU, and not base it on how good it makes that girls hair feel in the wind :hairtrick: . Good luck though! You dont like your super lows?? Ive got a single 15 on 3kw and it puts out a good hair trick. box is tuned to 30hz with 40 sq inchs of port area. I usually have my best tricks ato 20 to 26 hz. this was my first hair trick, 20 hz, single 15, 3kw, 2 cubes, 25 sq inches of port. 22hz tuning(long skinny port. i have a vid of my new setup doin one somewhere seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
