qts=0.36
vas=56L
fs=26Hz
Re=4ohms
xmax=28mm (1.102 inch)
z=8ohms
qms=8.77
qes=0.37
spl=93.9dB
rms=450w
pe=900w
bl=18.00
dia=305mm (12.01inch)
sd=0.048sqm
It's sensitive, it'll handle 400w, 4 ohms, big xmax
it need a decent size ported box, or mid sized sealed
816-591-6592
www.kcrimshop.com
qts=0.36
vas=56L
fs=26Hz
Re=4ohms
z=8ohms
qms=8.77
qes=0.37
spl=93.9dB
rms=450w
pe=900w
bl=18.00
sd=0.048sqm
Im impressed you had /found those specs. I couldn't find those on the 12150. Good work.
Have you tried any of the Max Fidelity subs?
Not personally, nope
816-591-6592
www.kcrimshop.com
  • Who's Online   0 Members, 0 Anonymous, 15123 Guests (See full list)
