I'm new here but I already have a shitload of questions! i wil start of with the thing i cant figure out how to do it without spendin a fortune, I wanna have a car amp (subwoofer) in my room, now here in europe i have 230 volts ac, i will have to get that to +/- 14 volts dc (i guess...) is there a way to do this wile still heving enough amps to keep the amp running for a low budget?? the amp sould be like 5000 watt peak
thnx! ^_^
thnx! ^_^
PC power supply.
Yellow wires are 12v+
Black is negative
Ground the green wire to turn the power supply on.
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
thnx! ^_^
just wire 3 or 4 together.
84 K5 Blazer
35" Maxxis Bighorn
100amp Alt
KnuKonceptz 1/0
Audiopipe AP-18001D
Kenwood KAC-645
--IN THE FUTURE--
None.
2 or 3 large car battery chargers and a battery or two.
PC Power supplies to supply the same amount of power will be more expensive and will deliver only 12 volts. Also some cannot be in parallel with each other without causing ground loop faults or other electrical feedback that will trip the protection circuits within the PSU's.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1065 Guests (See full list)
