ok now this is the config for my subs at 1 ohm
now could i switch the sides around an wire it to the amp on the right side an still get a 1 ohm laod or do i have to do it the way it says
kia spectra 4 door
HU-a kenwood kdc-692x
optima red top under the hood ( kinetik battery or powermaster in the back )
Iraggi 260amp H/O alternator
1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming )
front speakers -
back speakers -
2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future)
Sundown 3500d( going to be 2 sometime )
i have boughten from - Bass14(smd), ddbump(caraudioclassifieds)
never seen this question before. as long as you have it wired like it says in the picture, even if the amp is 20ft away from the box itll still be wired the same way.
Yeah i mean as long as you have the two negs together and the two pos and jumpers on each sub, it'd be just fine. It's kind of difficult understand exactly what you asking without some more explanation but just check your wiring before you hook everything up and you'll be fine.
1997 Dodge Ram Van 2500
Big III addition with 1/0 awg wiring all throughout
Lightning Audio Strike S4.1000.1D
Jenson XA2250
2 - 12" Mtx Jackhammers JH55
3ft cubed box sealed under the rear bench seat
Pioneer DEH-P6000UB head unit
MB Quart FWA 160 components up front
i think he means having the amp on the right side instead of the left as it is in that pic.....lol
yes my amp if u look in from the trunk my amp is on the right side an i dont think i have enough speaker wire long enough to run the subs from the left side all the way to the right side so i was just gonna fli flop it to were the subs come out on the right an get hooked up to my amp bc my power an ground an speaker channels on my amp are on the right an rcas on the left side of my blazer
kia spectra 4 door
front speakers -
back speakers -
well you can look at is this way, turn the picture of the wiring upside down and there you have your wiring diagram. just gotta match the wiring only the opposite way and everything will work out if its wired correctly.
Jenson XA2250
alright so it should work then if i flip flop sides just wanted to make sure bc if not i was just gonna wire each one to 2 ohm an wire it up to each channel
kia spectra 4 door
front speakers -
back speakers -
ok i hooked them up at 2 ohm each an there out of phase there is no loose connections inside or out side the box or the amp an they werent like this b4 i took them out an they been in my room this whole winter so idk tomorrow imma take them out an re wire them again
kia spectra 4 door
front speakers -
back speakers -
out of phase doesnt mean that theres loose connections. it means that you switched a + and - by accident...wire them like this
Edited by Kranny
alright thank man
kia spectra 4 door
front speakers -
back speakers -
