Just trying to help out, but 14-16 is what i use personally...
HU...Pioneer 5900IB
Wireing...Stinger
Amps...(1) Modded Stetsom 2K6..
Batts...(1) Stinger 2150
SPL Subs...(2) DD 9515 Hybrids
Daily Subs..(1) Mmats P3.0 15
N.S.P.L.
2012 NC State Record Trunk 1801-3600
2012 World Record Trunk 1801-3600
2011 NC State Record No Wall 0-24"
2011 NC State Record No Wall 0-24" Hardcore
2011 World Record No Wall 0-24"
2011 World Record No Wall 0-24" Hardcore
2010 World Record No Wall 0-2500w
2010 NC State Record No Wall 0-2500w
2009 NC State Record No Wall 0-24"
2009 NC State Record No Wall Hardcore 0-24"
yea i can figure everything out, its just knowing how much to use, the box i have designed is going to use 93 sq inches of port. so its either that, or do 100 sq inches. but i figured i would be safe at 15. and i believe 20 is more for spl
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
now does anyone want to be kind and do me up a sketch of this, im a retard when it comes to that, here are my xposports calc's
6 10" Sundown sa's
box height - 29
depth - 14
Length - 43
Port height - 12.5
width - 7.5
length - 24.5
net air space 6.24ft3. port area 93.75 in2. @32.33
subs forward, port up (drivers side)
thanks if anyone could do that!!
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
Something to think about:
If the port is facing up, a 24.5" port wall will not work with a 7.5" width and a box 29" high. Leaves an opening inside the box only 3.75" wide (needs to be 7.5" wide).
If you shorten the port wall up so the opening is 7.5" wide, then the port length including the corner is 29". You can add a 45 in the corner behind the port (make sure the width never drops below 7.5" wide), and this will shorten the length through the corner slightly.
Not sure what the driver displacement is for those subs, but assuming ~.1, you are left with 6 ft^3. A ~27-29" port length is ~32 hz tuning.
It will definitely work, just wanted to make sure you noticed the port length vs. box height. . .
Brian
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Brian
thanks brian, i already knew about that, tried to draw it up on paper and wasn't working out, i know the port was coming out to 29 was hoping someone knew what was wrong with that, i do plan on putting a 45 in the corner, and all those numbers have the displacement of the sub already, those numbers are all after displacement of the subs. (those specs of box are final after all displacement) i just dont understand how im going to get it to work.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
