plate amp bad cap?
I am pretty sure I have a bad capacitor in my plate amp. The top is not flat like the other it is bubbled up shaped. Would that bad cap cause a random popping sound to come from subs during usage, or do you think there is something else wrong? I hope not, I ordered 3 caps, I figured I would replace both of them. 3rd is just a spare also, do you think i can discharge them with like a night light bulb while on the circuit board? They are 6800 uF 80 V . Think I popped the cap when putting it in new box, hole was a tad but 2 small and i bent it over a lil bit and heard a noise come from the woofers. =(
Q # 2 I bought this plate amp off ebay some time ago for like $30 in an auction. But, there was no info on it, No brand or wattage out put. Where the plug plugs into the amp its says 240 VAC ,50Hz and 120 VAC , 60Hz and under that 450Watts, can someone convert that to approx output? Its kinda beefy and weighs alot. here are some pics of it its approx 10"x10" guessing 15-20 Lbs maybe a tad more. Any way to find wattage with dmm? Please dont laugh at my box to much, I had lowes do most of the cutting and I popped it together in like 90 mins putting the screws in by hand. Didn't want to keep changing the drill bit.
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
Replaced the caps, works great again! :)
Alpine CDA-9847 HU
