audiopipe 3000
tumminellon
Uhm... the low pass is usually set to your liking for the most part depending on the style of music you'd like to play.
I owned two of those amps and had HDC3 12's... Subsonic was set at around 26hz -28hz.. an I had the lowpass at about 65-70ish... Sounded pretty beastly an the subs moved an assload of air with a box tuning of 35hz
Bass boost/freq isn't worth the hassle, just don't get to heavy on the gains because you will clip your signal fairly easy... They don't like any line driver voltage over the recommended amount either..lol
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
