audiopipe 3000
tumminellon
how do i properly set the amplifier settings beside the gain (subsonic, bass boost, bass boost frequency, and low pass.) i set the gain at 77.46 since imm running it at 2 ohms. but i dont know what i set everything else to. also what do i set the sub outut settings on the radio its a pionner.
TermLab 148.9 @ 39hz BURP
148.8 on music
whats your box tuned to? what sub?
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
bump
**EDIT** by newls1
Did you really have to "bump" a thread that was last replied to within 40 minutes prior to your "bump" SERIOUSLY, dont do that shit
148.8 on music
Don't know anything specifically about your amp, but in general:
Subsonic filter just filters out super low frequency stuff to prevent the sub from getting damaged...set it a few hz under your tuning. I guess in the high 20s for your application.
Bass boost ideally shouldn't be used. Leave it all the way down.
Low pass filter is just the point where it starts filtering the highs out. I usually set mine around 80 hz.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
why shouldnt the bass boost/ bass boost frequency be used?
148.8 on music
Bass boost isn't really needed. You should turn off bass boost on your amp and your headunit before you set your gain on the amp. Bass boost is more than likely going to make your amp clip, which is bad.
Pioneer DEH-P6000UB
Sundown SAX-50.4
Sundown SAX-1200D
Stock Bose system
Profile AP1000M
i run ( this if for you decaf )
2 audiopipe 3000s (ones in for warrenty..user error) and all i use is the gain nothing else just be carefull on what you play.... dont play bigpimpins let my beat pound full tilt lol you will bottom your sub out realllllly bad
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
