iwnichols09 Posted January 27, 2010 Report Posted January 27, 2010 i was thinkn of gettin a optima red top batt. to put in da bak. Does ne body know if that will harm my alternator. I heard it will and i heard it won't so i just wanna hear yalls opinion Ian Nichols
Enellz Posted January 27, 2010 Report Posted January 27, 2010 i was thinkn of gettin a optima red top batt. to put in da bak. Does ne body know if that will harm my alternator. I heard it will and i heard it won't so i just wanna hear yalls opinion No it wont hurt your alternator at all what so ever. Just wire it parrallel from the front. Postive to positive, negative to negative (or ground it in the back(please make sure you sand all your grounds)). Your fine for now. One or two extra batteries are pretty much the most I would go on a stock alternator before I would upgrade to a high output alternator 2003 CHEVY TRAILBLAZER AKA The Batmobile Pioneer 6000UB Sundown SAZ-3000D 2 Audio Q HDC3's 40' of 1/0 Gauge 2 Big Rear Batteries A 38 HZ Box KICK ASS!
iwnichols09 Posted January 27, 2010 Author Report Posted January 27, 2010 No it wont hurt your alternator at all what so ever. Just wire it parrallel from the front. Postive to positive, negative to negative (or ground it in the back(please make sure you sand all your grounds)). Your fine for now. One or two extra batteries are pretty much the most I would go on a stock alternator before I would upgrade to a high output alternator ok thankz Ian Nichols
Tebo Posted January 27, 2010 Report Posted January 27, 2010 If you are only adding one battery you will be fine, If you add 2 or 3 batts its going to put a good amount of strain on the alt and it could either get weaker and not be able to charge you bank back up or just straight die. 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
