My SH**TY first system is composed of a Visionik 12" Sub in a sealed box, with a 3 or 5 hundred watt amp. Im not sure. But my problem is that about a week ago, I flipped my sub to face up so that it wouldn't be bouncing off of the back of my seat, and since my amp has gone into protect mode. I flipped it back over, checked all the mires, fuses, EVERYTHING. the sub is good and all. I cannot figure out why it keeps going into protect mode. If i take the wires out of the back of the sub and put them back in it will turn green, but as soon as i play music the sub with hit for about 1 second before the amp shuts off and turns back to protect mode. PLEASSEEE HELP.
Is this a dual voice coil sub? Maybe you wired it to too low an ohm load for your amp when you flipped it.
97 Maxima SE
Bunch of shit going in, check out the build
If wiggling them causes the sub to jolt on and off then there is likely a wire grounding out somewhere or the coils may have shorted together.
Make sure your wires are clean all the way from the amp to the sub and all connections between (no ends poking out all over touching things they shouldnt) and that the connections at each terminal (on sub, box, and amp) are all clean.
I'm going to bet there is a loose wire inside the box.
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 1316 Guests (See full list)
