rc.btl Posted February 1, 2010 Report Share Posted February 1, 2010 Hey guys i just want a nice box for those 2 tens i have right now... just shoot out ideas im open to anything. i want around 30hz and i want alot of port to move some air. thanks for your help. 2004 Grand Prix HU: Alpine 9886 for sale Sub Amp:AQ2200d (possbly 2) Enclosure:BCP Designs. Best for the Money Electrical:1 Stinger SPV70 battery Subs:2 15 D2 AQ HDC coppers Wiring:0gauge power SoundQuest Wiring:0gauge ground Kicker 141.8 @ 28hz tl legal on the dash. 142.6 @ 33hz tl legal on the dash. Link to comment Share on other sites More sharing options...
rc.btl Posted February 1, 2010 Author Report Share Posted February 1, 2010 bump 2004 Grand Prix HU: Alpine 9886 for sale Sub Amp:AQ2200d (possbly 2) Enclosure:BCP Designs. Best for the Money Electrical:1 Stinger SPV70 battery Subs:2 15 D2 AQ HDC coppers Wiring:0gauge power SoundQuest Wiring:0gauge ground Kicker 141.8 @ 28hz tl legal on the dash. 142.6 @ 33hz tl legal on the dash. Link to comment Share on other sites More sharing options...
bombout800 Posted February 2, 2010 Report Share Posted February 2, 2010 I wouldn't go more than 14 sq inches of port per woofer. I used to run smaller ports with these things a while back and they played a tad lower and more controlled. How much power do you have? How much power can depend on what size box to run. If you want 3 cubes do HxWxD: 15x30x19. with the port 10.5x4x19.5(42 sq. inches, 35.18hz). After subs and port you should be somewhere around 3.05 do some dowel bracing and you should be right around 3 cubes. If your going to be running a aq2200d to these things you may way a little bit smaller box. I'd say around 2.5 cubes. Someone can verify this to be sure. 03 350Z Link to comment Share on other sites More sharing options...
rc.btl Posted February 3, 2010 Author Report Share Posted February 3, 2010 I wouldn't go more than 14 sq inches of port per woofer. I used to run smaller ports with these things a while back and they played a tad lower and more controlled. How much power do you have? How much power can depend on what size box to run. If you want 3 cubes do HxWxD: 15x30x19. with the port 10.5x4x19.5(42 sq. inches, 35.18hz). After subs and port you should be somewhere around 3.05 do some dowel bracing and you should be right around 3 cubes.If your going to be running a aq2200d to these things you may way a little bit smaller box. I'd say around 2.5 cubes. Someone can verify this to be sure. ive got a top and bottom made... ill post pics and a vid sometime tmr or thursday 2004 Grand Prix HU: Alpine 9886 for sale Sub Amp:AQ2200d (possbly 2) Enclosure:BCP Designs. Best for the Money Electrical:1 Stinger SPV70 battery Subs:2 15 D2 AQ HDC coppers Wiring:0gauge power SoundQuest Wiring:0gauge ground Kicker 141.8 @ 28hz tl legal on the dash. 142.6 @ 33hz tl legal on the dash. Link to comment Share on other sites More sharing options...
