Rogers Posted February 1, 2010 Report Posted February 1, 2010 what Boon said.... make sure the fuses between the batts are good, make sure the rear batt is grounded properly, and see what the voltage is on that rear battery... then if that doesnt solve it... try running a temporary set of rca cables to see if that is the problem... also i saw that you said that your volt meters power and remote were hooked up to the amps remote terminal... this will do nothing for you accept look pretty..because the remote wire from the HU to the amp is supposed to be a constant voltage... hook the volt meters power wire into the amplifier positive or even to the rear battery positive... but leave the volt meters remote in the amps remote spot... this is fine... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
Hawaiian_Punch Posted February 2, 2010 Author Report Posted February 2, 2010 alright guys so i checked the anl fuse between the amp and rear batt, and also the one going from the front batt to the rear. they seem to be fine. and rogers, thanks for the heads up. i had a feeling about that being wrong. im gonna try and check my rca's and rca output rings. i hope to smash this today. wish me luck! Rogers: i noticed in your sig, the team deadly hertz. how do u become a part of that?. i seen a guy in hawaii wearing the hat and stickers on his truck 808 All Day Baby.. Yes Im From Hawaii & No I Dont Live In a Grass Shack 1990 2 Door 4Runner - Kenwood KDC-MP642U (changing out for a pioneer soon) - Pioneer speakers up front w/ tweets (in progress) - 18ft. of 0gauge, (3) 150 amp ANL Fuse - Sundown Sae-1200D - Stinger Blue Volt Meter - Yellow top up front, Die hard in the rear ( i know i know!!! it willl be changed soon!!) - 15 Fi Q - 4 cube box tuned to 31hz
