Hawaiian_Punch Posted February 1, 2010 Report Posted February 1, 2010 well i recently picked up this amp from a friend, i had it powering my temporary sub (15" CVR) till my Fi gets in. every now and then my sub would turn off and the amp would go into protection. i couldnt figure out the problem, so i would turn my car off and then start it again and it would bump for a little while then go off again. first i thought it was either my remote wire or rca's so i changed both. still same thing. so im thinking could it be that my kenwood deck is only putting out 2.5 volt outputs?!?!?. does that make any sense?... probably not. so i disconnected my sub and still when i start my car the amp stays in protect. i have checked my ground numerous times. and also checked all my 150 amp ANL fuses, they are fine. just to clarify I DID search but didnt find my solution. c'mon guys help me out!!!! this is making go NUTS!!! i wanna be able to bump my Fi Q when it gets here. any help is appreciated. my system details are in my sig if needed 808 All Day Baby.. Yes Im From Hawaii & No I Dont Live In a Grass Shack 1990 2 Door 4Runner - Kenwood KDC-MP642U (changing out for a pioneer soon) - Pioneer speakers up front w/ tweets (in progress) - 18ft. of 0gauge, (3) 150 amp ANL Fuse - Sundown Sae-1200D - Stinger Blue Volt Meter - Yellow top up front, Die hard in the rear ( i know i know!!! it willl be changed soon!!) - 15 Fi Q - 4 cube box tuned to 31hz
Hawaiian_Punch Posted February 1, 2010 Author Report Posted February 1, 2010 Anyone? please , please help.... 808 All Day Baby.. Yes Im From Hawaii & No I Dont Live In a Grass Shack 1990 2 Door 4Runner - Kenwood KDC-MP642U (changing out for a pioneer soon) - Pioneer speakers up front w/ tweets (in progress) - 18ft. of 0gauge, (3) 150 amp ANL Fuse - Sundown Sae-1200D - Stinger Blue Volt Meter - Yellow top up front, Die hard in the rear ( i know i know!!! it willl be changed soon!!) - 15 Fi Q - 4 cube box tuned to 31hz
Hotdog Posted February 1, 2010 Report Posted February 1, 2010 Anyone? please , please help.... What ohm is your sub (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Thewes Posted February 1, 2010 Report Posted February 1, 2010 Anyone? please , please help.... is the amp running at 1 ohm?
Hawaiian_Punch Posted February 1, 2010 Author Report Posted February 1, 2010 im such a dumb ass, sorry. my sub is dual 2 , and of course wired to 1 ohm. My Fi Q coming in is also a dual 2 808 All Day Baby.. Yes Im From Hawaii & No I Dont Live In a Grass Shack 1990 2 Door 4Runner - Kenwood KDC-MP642U (changing out for a pioneer soon) - Pioneer speakers up front w/ tweets (in progress) - 18ft. of 0gauge, (3) 150 amp ANL Fuse - Sundown Sae-1200D - Stinger Blue Volt Meter - Yellow top up front, Die hard in the rear ( i know i know!!! it willl be changed soon!!) - 15 Fi Q - 4 cube box tuned to 31hz
Hawaiian_Punch Posted February 1, 2010 Author Report Posted February 1, 2010 ok here's a dumb question.... what is the "correct" way to wire up a 1 ohm stable amp?. Flame on, i know... 808 All Day Baby.. Yes Im From Hawaii & No I Dont Live In a Grass Shack 1990 2 Door 4Runner - Kenwood KDC-MP642U (changing out for a pioneer soon) - Pioneer speakers up front w/ tweets (in progress) - 18ft. of 0gauge, (3) 150 amp ANL Fuse - Sundown Sae-1200D - Stinger Blue Volt Meter - Yellow top up front, Die hard in the rear ( i know i know!!! it willl be changed soon!!) - 15 Fi Q - 4 cube box tuned to 31hz
tehbert0 Posted February 1, 2010 Report Posted February 1, 2010 whats your voltage at http://motorcitydesignsaudio.com
Thewes Posted February 1, 2010 Report Posted February 1, 2010 It should be wired in parallel to bring it to a 1 ohm load, only problem I could think of would be voltage drop.
Steph3n1 Posted February 1, 2010 Report Posted February 1, 2010 It should be wired in parallel to bring it to a 1 ohm load, only problem I could think of would be voltage drop. yea heel right. but i dont think ive even seen voltage drops an an car below 11. and sundown amps can run something redicilously low like 8v or 10 2005 Ford Ranger Reg cab Build in Progress T3 Audio T2000 12 ARC SE4000 Stinger HPM 1/0 Wire DC power 270xp Batts: 1 Redtop up front and a Stinger SPP2250 in the back Hopes to be in and around a 150....weel see my youtube channel http://www.youtube.com/user/steph3n1 Team DBs (Driven By sound)
Hawaiian_Punch Posted February 1, 2010 Author Report Posted February 1, 2010 well honestly when i had the sub hooked up, as soon as i start my car up and try to turn my vol up it would cut out on very very LOW vol. which is weird. so my volt meter would still be at 13.8-13.9 where it usually sits when im not playing music. and i know how to wire up the sub, but i mean does it matter which terminals on the amp i use? i think i had it on the farthest ones , so the first negative , and the last positive. kinda like this.... {-} { } { } {+} if that helps...lol 808 All Day Baby.. Yes Im From Hawaii & No I Dont Live In a Grass Shack 1990 2 Door 4Runner - Kenwood KDC-MP642U (changing out for a pioneer soon) - Pioneer speakers up front w/ tweets (in progress) - 18ft. of 0gauge, (3) 150 amp ANL Fuse - Sundown Sae-1200D - Stinger Blue Volt Meter - Yellow top up front, Die hard in the rear ( i know i know!!! it willl be changed soon!!) - 15 Fi Q - 4 cube box tuned to 31hz
