01 S-10 Posted February 2, 2010 Report Posted February 2, 2010 Your S-10 should already have a voltage gauge in the dash right? TDH FTW !!!
BeachJoshua Posted February 2, 2010 Author Report Posted February 2, 2010 Your S-10 should already have a voltage gauge in the dash right? Yes, but how accurate is that? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
01 S-10 Posted February 2, 2010 Report Posted February 2, 2010 Yes, but how accurate is that? accurate enough to get rid of that capacitor. Seriously even if u can't afford the battery right now take the cap out, its hurting more than helping! TDH FTW !!!
Menace89 Posted February 2, 2010 Report Posted February 2, 2010 I just happen to have a Kinetic HC600 for sale if ur interested
BeachJoshua Posted February 2, 2010 Author Report Posted February 2, 2010 accurate enough to get rid of that capacitor. Seriously even if u can't afford the battery right now take the cap out, its hurting more than helping! Okay... well you tell me why a cap is hurting? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
BeachJoshua Posted February 4, 2010 Author Report Posted February 4, 2010 Anyone? How does a Capacitor hurt? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
t-money Posted February 4, 2010 Report Posted February 4, 2010 Anyone? How does a Capacitor hurt? caps dont help u unless you have a great charging system anyway. all a cap does is help to smooth out voltage ripple. but if u dont have the power to back it up it wont help u. besides if u have a good charging system (H/O alt). then u shouldnt have voltage issues. batterys will do 200 times better than caps. caps DO NOT store power like battery's do 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
BeachJoshua Posted February 4, 2010 Author Report Posted February 4, 2010 caps dont help u unless you have a great charging system anyway. all a cap does is help to smooth out voltage ripple. but if u dont have the power to back it up it wont help u. besides if u have a good charging system (H/O alt). then u shouldnt have voltage issues. batterys will do 200 times better than caps. caps DO NOT store power like battery's do So is it hurting, or just not doing anything at all? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
BeachJoshua Posted February 14, 2010 Author Report Posted February 14, 2010 Today I purchased: 4' x 8' x 3/4" MDF Tube of liquid nails 1 Gallon fiberglass resin Pack of fiberglass mat Total: $125.00 Roughly Accomplished: Removed 100 Amp fuse from battery Removed rear plastic Removed seats Removed jump seats Removed rear panel carpet and plastic Sprayed on sound deadener Went to block buster Traded in movies in the mail Got Inglorious Bastards and some movie my dad got Went to Lowe's Purchased above items Went to Bi-Lo bought some sodas Went home Put up sodas, fiberglass, and liquid nails Got out circular saw, trash can, square, level, tape measure. Started cutting MDF Test fit, trim, repeat Took pictures | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
BeachJoshua Posted February 14, 2010 Author Report Posted February 14, 2010 | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
