r00k Posted February 2, 2010 Report Posted February 2, 2010 Ok ...here's the subs i have(2): http://www.jo-dis.com/ProductDetail.aspx?ProductID=PLW15D2 Here's my amp: http://www.rockfordfosgate.com/products/pr...mp;locale=en_US SO basically i'm using one side of this 4 channel amp bridged to power both of these. What ohm am i at i have no idea. What i'm wanting to know is if there's another way to wire this up or do something different to get more thump. If not what other amp or suggestions would you guys do to make it louder. Thanks for any help!! EDIT: Thought about buying this for the subs and using my T4000 for interior speakers?? (Advice) http://www.audioque.com/aq/?page_id=28 r00k
matt402 Posted February 2, 2010 Report Posted February 2, 2010 ya, put the mono block on subs 4ch on speakaz... are ur subs d2 or d4?
STEvil Posted February 2, 2010 Report Posted February 2, 2010 Put 1 sub on each half of the 4 channel or get the AudioQue for them. Put the VC's in series on each sub to the bridged terminals on the 4ch amp.. should save you from killing it. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
r00k Posted February 2, 2010 Author Report Posted February 2, 2010 Matt i have no idea lol and STEvil i have no idea what any of that means?? The subs came in a prefab box so i haven't taken them out to look at them. I'm only using one side of the 4 channel and i have it bridged. Was wondering if i should use one side per sub and if bridging it would drop it an ohm or ...hell i don't know what i'm saying but i'm sure someone here gets what i'm looking for. Until i get a new amp i want the most bass i can get out of the 4 channel. If possible in easy to read and understand terms lol. Thanks again guys! r00k
