07 Avalnche 2 18 FI Sundown 3500d Zapco 1000.4 Reference
quick question, why the concrete ?
R.I.P!
(Nov-29-2009)
92 explorer
current build
I cut a board the same shape as the factory midgate to seal the cabin from the bed the bed has a rubber seal that the midgate presses up against it and seals the cab. This board will be inside the truck i will remove the hardware latch from the factory midgate and screw it on my mdf midgate and use the bottom hinges to press the board againts the seal
