tobio19 Posted February 3, 2010 Report Posted February 3, 2010 hey guys got my btl today and wired it up to my amp to see if it works so wired it at 2ohm + to + and - to - on the other side the + on sub to + on other side and - to - on other side.... well, like this lol http://www.the12volt.com/caraudio/woofer_c...sp?Q=1&I=22 and it doesnt work.... amp is aq2200d sub is 18" btl d2ohm thankyouu Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
Tooshort064 Posted February 3, 2010 Report Posted February 3, 2010 (edited) is it a dual 2 or dual 1 ohm sub ? nvm dual 2 you cannot wire to 2 ohm its either 1 ohm or 4 ohm Edited February 3, 2010 by Tooshort064 Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
tobio19 Posted February 3, 2010 Author Report Posted February 3, 2010 is it a dual 2 or dual 1 ohm sub ? i said its dual 2ohm Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
Tooshort064 Posted February 3, 2010 Report Posted February 3, 2010 (edited) it either wires 1 ohm or 4 ohm dual 2 cannot be wired to 2 ohm. how ever connect all + and all negatives together and plug that way. if you have by accident plugged a - and a + together the sub will not play and is shorting out! Edited February 3, 2010 by Tooshort064 Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
tehbert0 Posted February 3, 2010 Report Posted February 3, 2010 are your gains set? on the h/u and amp Quote http://motorcitydesignsaudio.com
tobio19 Posted February 3, 2010 Author Report Posted February 3, 2010 it either wires 1 ohm or 4 ohm dual 2 cannot be wired to 2 ohm.how ever connect all + and all negatives together and plug that way. if you have by accident plugged a - and a + together the sub will not play and is shorting out! yeah sorry thats what i meant, the sub is 2ohm but wired to 1ohm so your way is that on both the coils, + and - are wired down into the amp + and - but only using 1 of the + and - on the amp..... yeah i fail at describing things lol Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
Tooshort064 Posted February 3, 2010 Report Posted February 3, 2010 (edited) are your gains set? on the h/u and amp true A buddy of mine was like my sub wont even play no output what so ever,after taking 3mins and looking at it well the sub output on the H/U was off . So yeah check that too! Edited February 3, 2010 by Tooshort064 Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
tobio19 Posted February 3, 2010 Author Report Posted February 3, 2010 are your gains set? on the h/u and amp ok im gonna look so stupid here lol, i just wanted to test it quickly before i set the gains properly with the multimetre.. Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
Tooshort064 Posted February 3, 2010 Report Posted February 3, 2010 yeah sorry thats what i meant, the sub is 2ohm but wired to 1ohmso your way is that on both the coils, + and - are wired down into the amp + and - but only using 1 of the + and - on the amp..... yeah i fail at describing things lol that is correct . Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
Tooshort064 Posted February 3, 2010 Report Posted February 3, 2010 pictures to show things when problems arise are the best thing on this forum. its difficult to understand what some people are saying and how there describing them. Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
