is what the same thing? the other outputs? the "front" and "rear" outputs will send a full range of the music and work with certain EQ settings on your deck. the subwoofer output only sends the lows and works with other EQ settings.
dam, here i thought i was done ripping my dash apart...
guess not, thanks one more question
under the carpet in my trunk there is really really thin sheet metal, can i use it as a ground or what cuz i cant find nothing else that is easily accesible
trailblazer
18" xl
aq2200
147.8db at 4 ohms
its best to run your ground back up to the front battery but yes, grounding to the trunk should be fine. find a supported spot if you can so there is more metal for the bolt to grab onto. be sure to sand off the paint.
A good place in the trunk is to ground to one of the strut tower bolts, just take off one of the outer bolts(NOT THE CENTER ONE!!!!!!) sand it down a good bit then bolt your ground to it.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 10444 Guests (See full list)
