gotswitched Posted June 4, 2007 Report Posted June 4, 2007 I have the MTX thunder ta7801 pushing a rockford t215 at 1 ohm..after about 20 minutes or so it will turn off for like 5 minutes..then turn back on, and today it was like cutting out but not turning off. Why would that be, is it not truly 1 ohm capable? its not really getting too warm either. 2 Rockford T2 15's in 8.5 cu ft box 1 Rockford T30001bd 1 Eclipse XA4000 4 channel 1 Rockford T162S component 1 Rockford T1693C
Chris Posted June 4, 2007 Report Posted June 4, 2007 You may have a voltage drop problem, & your battery up front may be dying slowly & your alt may not be able to keep up with the amp draw. What kind of electrical are you running? 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR.
